Forums >> General Discussion >> Wishlist >> timber frame panels
3 Posts No Rating |
Has Any one got a timber frame panel family is adjustable and scheduable ? . or suggest how to create one ?
I've tried varous option and can get any thing to work
Thanks
Alistair
Do you mean like Strong tie Shear walls?
3 Posts No Rating |
No. I'm try to create a SIPS type paneling system, the standard wall framing command within revit2012 is to complected and time consuming , when trying to do 3m long panels, on a 100m wall plus all the jounts windows ect.
I am working on something at the moment, & am using a framing family I created to do this. You could modify it to suit your project
3 Posts No Rating |
Many thanks it very similar to what i'm looking for, I can adjust to suit.
you might also try the railing command, you can set up spacing of post, and then a panel section.
timber frame valleys |
Wed, Apr 18, 2007 at 3:06:59 PM
Timber Framing |
Tue, May 9, 2006 at 9:04:39 AM
Timber framing in Revit? |
Tue, May 18, 2004 at 11:46:22 AM
How would I go about creating a timber frame? |
Fri, Feb 10, 2006 at 3:49:50 PM
Timber Frame Roo |
Fri, Feb 20, 2015 at 4:00:53 AM
Members: | 2115045 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
