26 Users Online (25 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> design options
Wed, Jan 11, 2012 at 1:53:13 AM | design options
karmon1
i 'm working with revit 2009. in design options. i inserted primery 1and then duplicated to options 2 and 3. i see the plan of option1 Crying the primery 1) in light lines and options 2 or 3 in bold. when i change to 3d mode i see both the option and the primary walls , so they are disturbing the view. is ther a way that the primary walls will not be created in the 3d ?
another problem, in primary1- ground plan i see all options, although in el.pr. visible in option- primary 1. and in visibility graphics- primary 1 ;op 2- auto. op 3-auto., how can i see only the primary 1- the main plan?
thanks.
Wed, Jan 11, 2012 at 7:17:57 AM | design options
You can set any view to display any one of your options in an option set but you have to have one option showing.
Did you by chance create mutiple option sets?  If so, then at least one option from each option set will show.  You can control which open in which set through your VG settings, Design Option tab.
Design options issues
Thu, Mar 2, 2006 at 10:35:31 AM
Design Options
Wed, Dec 24, 2003 at 10:33:51 AM
Titleblocks & Design Options
Mon, Dec 8, 2008 at 2:06:33 PM
design options tied to other objects (version 2008)
Tue, Apr 1, 2008 at 6:17:36 AM
Text In Design Options
Fri, May 28, 2010 at 3:25:07 PM
Page generation time: 6.7835
