62 Users Online (60 Members):
Forums >> Revit Systems >> Technical Support >> Revit 2012 running slowly!
2 Posts No Rating |
I just installed Revit Architecture 2012,and it's running extremely slow,It pause everytime i do anything(zooming,selecting,...).I was working with 2011 version before,and it dosen't have any problem.and the file that I'm working is not too heavy,it's just 20MB!
Ps:I'm running HP Pavillion Dv6/intel core i7-2670qm CPU @ 2.20ghz/8 GB ram/windows 7 64bit
Edited on: Tue, Jan 10, 2012 at 5:42:51 AM
![teafoe5 Avatar](user_avatar/204239.jpg)
![4 Stars: 47 Votes](/images/stars_4.gif) |
If you have been running revit for an extended period of time its suggested that you close revit completely to relinquish the memory that it has used then restart it up. Not sure it this will fix your problem but it works when mine starts running a little slowly.
![alabaster2513 Avatar](user_avatar/28262.jpg)
![3.5 Stars: 25 Votes](/images/stars_3.5.gif) |
have you checked your driver compatibility and hardware acceleration? 2012 does have a couple more visual options that use more system resources. when testing a project in one release verses another I like to open the project in each version then in my task manager i set the process affinity for each to their own individual processor. then i click and open views in each version as fast as i can, zoom and pan. I also do something similar with families. I'll copy them 1000 times and switch views and open views a bunch of times to see what impact it has on the project.
2 Posts No Rating |
thank you both for your responds , I actually seasrched more here at that time and checked hardware accelration .I have this warning in my Graphics -->"Unknowen vedio card" ! and I turn off Hardware accelration as it was suggessted there,and it's worked ...so far so good ![Smile](/images/smiles/smile.gif)
Revit 2013 running slow - anyone have the same issues? |
Sat, Mar 1, 2014 at 1:37:56 PM
Revit 2012 in 1366x768 monitor? ... any issue? |
Sat, Feb 25, 2012 at 7:01:16 AM
.pat file - running bond with angled tiles |
Thu, Mar 30, 2017 at 6:28:09 PM
Revit 2012 Architecture - Stability Issue |
Fri, Sep 16, 2011 at 8:56:37 AM
MEP 2012 Electrical Tick Marks Problem |
Thu, May 26, 2011 at 4:46:24 PM
Members: | 2017209 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
