Forums >> Revit Structure >> Technical Support >> Framing extension
41 Posts No Rating |
I use Revit Architecture and structure 2011 programs. Is it possible to insert a floor plan from Revit architecture into the structure program and use the framing extension to create a 3d view of the framing?
Just link the Revit architecture file. Or, if the file is not too large, just use the Architecture file.
All of the Revit programs can use the same file. The differences are within the program.
OK I have the plan in the structure program but when I select the walls for framing I get the message "no walls selected". Does this import need to be exploded or some similar operation?
You say import, so I assume you linked the file? If so, copy monitor the walls, then turn off the linked file's walls.
Still not sure what you are trying to do. If you don't need seperate structural documents, you might be better off just using the architectural file.
Edited on: Mon, Jan 9, 2012 at 10:24:47 AM
Wood Framing Walls Extension; Locating and External framing |
Fri, Jul 31, 2015 at 8:03:15 PM
wood framing extension |
Mon, May 7, 2012 at 3:23:49 PM
Wood Framing Walls Extension Review |
Thu, Sep 23, 2010 at 2:51:07 PM
Revit Wood Framing Extension |
Wed, Jun 1, 2016 at 5:17:19 PM
wood framing wall extension |
Tue, Aug 16, 2011 at 4:13:21 PM
Members: | 2114960 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
