99 Users Online (98 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Curved Cabinet front
Fri, Jan 6, 2012 at 11:15:41 AM | Curved Cabinet front
jlueck
Hi,  I am wondering is it possible to do a sweep on the face of a curved object.  I am trying to make a curved front base cabinet and can not figure out how to sweep my door profile to a curve.  If anyone has and sugestions on how to accoplish this that would be great- Revit 2012
Fri, Jan 6, 2012 at 11:28:46 AM | Curved Cabinet front
If you are trying to do a paneled door as a sweep, you will have to do it in pieces doing the rails seperate from the stile & panel.  That is because the stile/panel profile does not cross the rails. Likewise, if this is a flat panel, you could do this as plan extrusions rather than sweeps.
I would create this as a family - not in-place.
Fri, Jan 6, 2012 at 11:33:34 AM | Curved Cabinet front
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
to expand a little on what WW, has said. set up workplanes for the top and bottom rails, and you may want to use void sweeps for the creation of the paneling detail. This will be a very expensive cabinet.
How do I cut cabinet to host recessed light? Using Revit 2009
Thu, Apr 17, 2008 at 10:00:03 AM
Front Curved Curtain Wall Question
Mon, Jan 30, 2017 at 1:28:16 PM
One cabinet is dashed and the one on side of it is solid
Thu, Jun 24, 2010 at 8:53:22 AM
How to display optional string in cabinet tag
Mon, Mar 25, 2019 at 12:40:43 PM
Cabinet Family which is Wall Hosted
Thu, Aug 4, 2011 at 11:09:06 AM
Page generation time: 1.1354
