36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Spot elevation - symbol line greyed out
Fri, Jan 6, 2012 at 2:13:06 AM | Spot elevation - symbol line greyed out
cpgdavinci
Hey everyone.. Having a problem, as We want to create a custom spot elevation symbol and load it into our project, which has been done just fine. Our problem is now that the spot elevations won't accept a symbol in the type properties (see attached image). Does anyone have any idea why this is or how i can change it?? I believe i have tried everything i know, but must admit that im not a RAC specialist.
CPG
Tue, Jan 17, 2012 at 3:44:56 PM | Spot elevation - symbol line greyed out
adriandiciahall
adriandiciahall Avatar
3.5 Stars: 3 Votes
Hi there. No revit expert either but i'm going to guess that the symbol option is gone because all unused spot elevation symbols have been purge from the project. If not then it means the symbol you loaded is not being recognized as a spot elevation symbol. Try opening and editing an existing spot elevation family  eg. “Spot Elevation - Target Filled” to your custom symbol and then open and load it into your project. It should become available after that. If not then I’m not sure what’s wrong. Hope this helps.
Spot elevation target symbol
Wed, May 27, 2015 at 5:09:17 PM
Spot elevation symbol [ 1 2 ]
Mon, Dec 1, 2008 at 10:10:59 AM
16
Target size of Spot Elevation (Revit Architecture 2008)
Wed, Aug 6, 2008 at 9:43:56 AM
Spot Elevation without Target
Fri, Mar 20, 2009 at 4:57:55 PM
Spot elevation tag issue
Mon, Jun 3, 2019 at 3:18:37 PM
Page generation time: 1.0236
