Forums >> Revit Building >> Technical Support >> Split Section
8 Posts No Rating |
Using Revit 2012, when I split a section, my windows no longer show up in section, only the voids are left. Is there a view setting or visual style that needs to be changed to allow for windows to be cut in a split section?
Scale is set to 1/4" = 1'-0" and detail level is "Fine". note, same issue holds for medum and course detail levels)
Is any one else experiancing this issue?
Thanks,
I don't have any problem, put some screenshots so we can see what are you talking about.
Ty - I believe he means that when the split goes through the window, it disappears.
If the above is the broblem, then it must be a family issue. I don't know what windows you are using but the stock Revit windows do not have this problem.
8 Posts No Rating |
Thanks guys, this issue occurs when you stagger the section line, ie. when I split it, and move one half say south 10 feet in order to hit a window on one side of the building, and a door opening on another with a singular section.
We are using Marvin Impervia Windows, downloaded direct from their website. Its possible it is their windows, I will try the standard Revit Stock windows as well.
As well as upload screen shots
Thanks,
1 Posts No Rating |
check out this post:
http://www.revitforum.org/architecture-general-revit-questions/15336-split-section-window-visibility-problem.html#post92335
Revit split section |
Mon, Jan 27, 2014 at 7:43:07 AM
Split Section |
Mon, Dec 2, 2013 at 8:05:45 AM
SPLIT A SEGMENT OF A SECTION |
Wed, Nov 8, 2023 at 12:46:55 PM
Split face conc masonry section |
Tue, Jun 7, 2011 at 11:07:52 AM
Split pitch in section |
Fri, Aug 12, 2005 at 12:47:50 AM
Members: | 2098026 | Objects: | 23164 | Forum Posts: | 152290 | Job Listings: | 3 |
