Forums >> General Discussion >> Revit Project Management >> How do i put my download on revit?
2 Posts No Rating |
I have downloaded files to revit but it wont allow me to put them in my drawings? we can put them in by accident but they are .jpg, but all the ones that are .rvt files we cant put it in. what do we do?
Thanks,
Brandon
AutoDesk Revit Architecture 2011
are they the same or lesser version of what you are using?
Edited on: Thu, Jan 5, 2012 at 8:04:30 AM
2 Posts No Rating |
it is the same version as the program that i have.
A jpg is an image file. You can place that on a sheet using the insert command, or you can use it in a decal. It is not a revit family and is really not usable as a "drawing" element.
your question is kind of unclear. Sounds like maybe your trying to Import some Revit Families but you what you need to do is Load them.
Under the 'Insert' Tab. go to 'Load Family'. Then find your family.
Under the 'Home' Tab. go to 'Component' and your family should appear in the drop down.
Download Revit 2010 Now!! |
Mon, Oct 12, 2009 at 10:42:37 AM
Is there a better Download Library around? |
Tue, Jul 3, 2007 at 7:20:03 PM
cannot download drawings from revitcity |
Sun, Jun 25, 2017 at 2:02:49 AM
download doesn;t work |
Fri, Jun 1, 2018 at 3:50:43 PM
how to download pattern in revit? 2009, 2008 etc... |
Thu, Aug 13, 2009 at 7:01:11 AM
Members: | 2114668 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
