52 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Ceiling grid line weight
Wed, Jan 4, 2012 at 10:50:32 PM | Ceiling grid line weight
mluedders
My new ceiling grids do not stand out against the existing ones.  How can I increase the line weight of a grid?  I can't find anything in the basic ceiling editor that lets me do this.
Thanks,
Matt
Thu, Jan 5, 2012 at 7:35:19 AM | Ceiling grid line weight
gebber
gebber Avatar
5 Stars: 4 Votes
There are several ways
1. Select the existing ceiling and set in the properties the phase created to existing (when your view is set to new) existing parts wil show greyed out.
2. duplicate the ceiling and make a second type, change the color of the surface patern.
3. select the existing ceiling rightclick and choose override grafics in view.
Thu, Jan 5, 2012 at 9:23:26 PM | Ceiling grid line weight
ml22
Thank you, gebber.
My problem, though, is not making a lighter lineweight for the existing.  The existing is light enough.  I'd like to make the new ceilings heavier.  They're already black.  How do I make the grid lines thicker?
Tue, Jan 17, 2012 at 1:39:05 AM | Ceiling grid line weight
gebber
gebber Avatar
5 Stars: 4 Votes
I now find the option in the print setup "replace halftone with thin lines"
To make the other lines heavier you can go to;
Manage -> Settings -> Objectstyles, here you can find Ceilings under Category,
under projection you can change the lineweight.
(Lineweights can be checked under Manage -> settings -> additional settings -> Lineweights)
Thu, Aug 29, 2013 at 12:48:47 PM | Ceiling grid line weight
Turandot
gebber, the suggested will change the picked line weight all over the project, in most of cases i wouldn't do that... i have the same issue: how to make the ceiling grid lines heavier?... in Object Styles i can change the thickness only of the ceiling outline, not the grid itself. It is Revit 2013
Wed, Aug 8, 2018 at 10:44:06 AM | Ceiling grid line weight
thinkpositive
5 Stars: 7 Votes
Was anyone able to solve this? How to make interior grid lines of a ceiling darker (meaning change line weight not color). Everything I do seems to change only the line weight of the ceiling outline.
Wed, Aug 8, 2018 at 11:10:16 AM | Ceiling grid line weight
Ceiling grids are really just a hatch pattern.   Read this.
Wed, Aug 8, 2018 at 4:33:13 PM | Ceiling grid line weight
thinkpositive
5 Stars: 7 Votes
Okay thanks.
Column Grid Line Weight
Sun, Aug 13, 2017 at 3:05:53 AM
Impossible to change ceiling pattern line weight
Tue, Jan 22, 2013 at 11:03:23 AM
Light fittings in ceiling grid
Tue, Feb 8, 2005 at 6:33:49 PM
Ceiling Grid
Wed, Mar 16, 2011 at 3:15:50 PM
Ceiling Grid Not Moveable?
Thu, Dec 16, 2010 at 12:15:57 PM
Page generation time: 1.8380
