Forums >> Community >> Newbies >> Sure hope you guys can help...
8 Posts No Rating |
I created a rib for a diewall with a generic floor based templet, now I am trying to get it to load into a generic line base templet so I can create the diewall parts and have it array the ribs. When I ask it to load it does, I can see it in the properties bar, but when i try to place it on the drawing I get a circle with a line thru it. What did I do wrong, and how do I fix it? The generic based .rfa is attached.
Note, this is my first attempt with a line based family, I may be missing something basic.
Thanks in advance...
"I created a rib for a diewall with a generic floor based templet" - Because of that.... the HOST is a FLOOR, that's why you have that "a circle with a line thru it." you cannot place that unless you have a FLOOR.
Create that to a "Generic Model" family then load to a "Line based" family.
8 Posts No Rating |
Thank you :D
Hope this forum is active! :) |
Fri, Dec 22, 2017 at 6:48:01 PM
Newbie Here.. Hope you can help me |
Wed, Sep 12, 2012 at 10:05:57 AM
importing.. help me guys |
Thu, Feb 26, 2009 at 3:17:32 PM
*New Revit User* Hey there |
Mon, Oct 13, 2014 at 10:38:17 AM
guys, i dearly, and i mean dearly need ur help on elevation default. |
Tue, Feb 18, 2014 at 5:08:43 AM
Members: | 2125957 | Objects: | 23225 | Forum Posts: | 152302 | Job Listings: | 3 |
