21 Users Online (20 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Room Tag w/ multiple lines of text
Wed, Jan 4, 2012 at 10:01:31 AM | Room Tag w/ multiple lines of text
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
How do I make a room tag that can have multiple lines of txt such as
mech/
storage
instead of mech/storage
Wed, Jan 4, 2012 at 10:16:56 AM | Room Tag w/ multiple lines of text
This is one of those areas that can be very complicated.
You can add as many lines as you want by adding additional parameters but I don't believe that is the question you are asking.  The problem is what you show here may not be what you want to show in a schedule and the schedule uses the same information.
This tag uses the "Room Name" parameter and is a fixed length.  So if you enter "mech/               storage", it will probably stack. (<< Notice the spaces)  Do you really want that name in your room schedule?
Your solutions are:
  1. Create a special tag that is short enough that it will break this in two lines without additional spaces.
  2. Add additional parameters to rooms like Tag line 1 and Tag line 2, then create a room tag that reads these two parameters instead of the room name.
The problem with #1, is that you may need several tags of different lengths in your project.  And #2 is not automatic.  If you change the room name, you have to remember to change these special tag values.
Mon, Apr 1, 2013 at 12:19:56 AM | Room Tag w/ multiple lines of text
jpmays23
You can also just adjustt the size of the text box.
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Multi-line-room-name/td-p/2837985
Mon, Apr 1, 2013 at 9:20:59 AM | Room Tag w/ multiple lines of text
jpmays - That was the answer #1 above  .......but it does come with problems as I also wrote.
Editing a room tag
Thu, Oct 12, 2017 at 3:17:41 PM
How do I create a Room Tag that has a text field that I can add comments too?
Mon, Nov 20, 2017 at 4:22:21 PM
Room tag - multiple finishes per room
Tue, Oct 14, 2008 at 2:21:49 AM
Room tag not showing in only one room. [ 1 2 ]
Fri, May 9, 2025 at 1:18:00 AM
27
Room Tag Leaders
Thu, Oct 21, 2021 at 9:45:56 AM
Page generation time: 1.3380
