66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> ARC LEADER NO TEXT
Wed, Jan 4, 2012 at 8:53:35 AM | ARC LEADER NO TEXT
vinnygolfer
4.5 Stars: 4 Votes
hi all, i'm just wondering if anyone has found a way to make an arc leader without text. i have used the blank leader from this site and it works great, but it wont do an arc. the problem is that i need to have an arc leader with an arrowhead and text at the end of the arrowhead.
by the way i'm using MEP 2012
thank you in advance
Try to learn at least one new thing every day
Wed, Jan 4, 2012 at 9:26:14 AM | ARC LEADER NO TEXT
coreed
coreed Avatar
4 Stars: 16 Votes
What do you mean by "it won't do an arc" and that you need to have "text at the end of the arrowhead".
Play Attached Video
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Jan 4, 2012 at 10:37:59 AM | ARC LEADER NO TEXT
vinnygolfer
4.5 Stars: 4 Votes
thank you that will work great for me. i was having a mind blank. didn't even concider using a dot that won't even show on the print.
Wed, Jan 4, 2012 at 10:47:48 AM | ARC LEADER NO TEXT
vinnygolfer
4.5 Stars: 4 Votes
COREED,
it worked great used one for the arc and a different text item for the note. it's for a control print, and it's similar to a homerun tag, but not.
Thu, May 2, 2013 at 10:36:04 AM | ARC LEADER NO TEXT
carmer
Awesome work around!  I LOVE THIS SITE!  thx.
Multiple Leader Text
Sun, Nov 18, 2007 at 12:33:40 PM
Distance from leader to text... Revit 2010
Tue, Jun 1, 2010 at 9:13:51 AM
distance between text and leader lines able to be changed?
Fri, Sep 12, 2008 at 10:20:21 AM
EDITING TEXT LEADER ARROWHEADS AND LINES
Thu, Aug 14, 2008 at 3:21:20 PM
drawing a leader/arrowhead without text?
Mon, May 31, 2010 at 10:54:51 AM
Page generation time: 1.8214
