67 Users Online (66 Members):
Forums >> Revit Building >> Technical Support >> BEAm
14 Posts No Rating |
can i make beam systems and have visibiliity of beams from the floor plan that i make that??
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
make sure your detail level is medium or fine,
your view range goes down maybe -200, if you still can't see it, go to wire frame view,
HTH
HTH
thanks a lot it was to easy ... but i'm a new user .. anddd .. thanks again
Meeting Beam Systems to Glulam Beam |
Wed, Jun 20, 2012 at 10:34:16 AM
Precast Beam System not sitting on beam |
Thu, Jan 10, 2013 at 11:45:48 AM
Steel Beam to Beam Connection |
Fri, Jun 18, 2010 at 1:54:36 PM
Beam & Beam systems |
Tue, Oct 21, 2008 at 4:36:54 PM
Beam/joist going through wall |
Thu, Sep 11, 2014 at 4:32:00 PM
Members: | 2017196 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
