87 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> rendering random panels
Tue, Jan 3, 2012 at 7:22:49 AM | rendering random panels
online2000
online2000 Avatar
can anyone think of a good way  to simulate in a render a different types of finishes for each panel of a curtain wall - without having to:
1/ manually change each type to anew type of panel
2/ and recreating the material to each one with a changes in mapping-- even if its the same but has a diffeerence orientation?
i show a samples that took some time- as mentioned above
option 1 shows how each panelhas a differnet mateerial
option 2 shoes bad result
is there away that you can think of that saves time-
was trying options like RING and WOOD finish- but there is no randomization to the surface- EACH panels applies the material from the same stat point.. and it doesnt look too cool
thanks
Eli
eli
Tue, Mar 20, 2018 at 5:32:58 PM | rendering random panels
online2000
online2000 Avatar
SOLVED
use a random tile an add cut pattern
thanks to myself
eli
Random slidding panels on a curved facade ?
Tue, Mar 1, 2011 at 9:56:45 PM
metal panels
Mon, Dec 20, 2004 at 6:01:44 PM
Random stone walls
Thu, Jun 26, 2008 at 5:04:39 PM
Turning certain curtain panels into spandrel panels
Tue, Dec 3, 2013 at 1:59:47 PM
Patterns generated by algorithyms for screening panels
Mon, Jul 15, 2013 at 10:41:47 PM
Page generation time: 0.4459
