41 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> wood floor
Sat, Dec 10, 2005 at 10:21:21 AM | wood floor
TOYRIS
how i can make a wood floor with tiling
Sat, Dec 10, 2005 at 10:29:06 AM | RE: wood floor
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
You should use the floor tool, and create a new floor type by opening the properties of the floor and clicking edit/new and then duplicate. The new floor type should be assigned a new material and that material should be assigned a tile fill pattern that you want (see the fill pattern section of this website) and a rendering material that you want.
Hiroshi Jacobs
Sun, Dec 11, 2005 at 7:11:49 AM | RE: wood floor
latemore
latemore Avatar
3 Stars: 2 Votes
something mr spot recommends and we now adopt is create layers of floors, ie how it is built. then you can have greater control. he even does this with roofs too. more work but it works much better later when you have to revise something.
Sun, Dec 11, 2005 at 9:09:26 AM | RE:
TOYRIS
Quoting hjacobs - 2005-12-10 10:29:06
"You should use the floor tool, and create a new floor type by opening the properties of the floor and clicking edit/new and then duplicate. The new floor type should be assigned a new material and that material should be assigned a tile fill pattern that you want (see the fill pattern section of this website) and a rendering material that you want."
THANKS A LOT!!! Smile)
Wood floor way too shiny.
Tue, Dec 14, 2010 at 7:32:39 AM
Wood Floor ,Pat
Thu, Feb 26, 2015 at 11:44:39 AM
Wood Floor
Fri, Apr 24, 2015 at 6:17:47 PM
wood deck
Sat, Aug 19, 2006 at 12:13:35 PM
How can you place a ceiling in a floor if theyre both 3D elements???
Wed, Dec 3, 2014 at 12:26:40 PM
Page generation time: 0.5482
