57 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Manipulating the Leader Line
Mon, Jan 2, 2012 at 10:35:13 AM | Manipulating the Leader Line
rwelliot3
Hope everyone had a great holiday and are off to a great New Year.  I have an issue with a wall tag that I created.  There is a box tilted 45 degrees with a note inside and a secondary note outside the box in a circle.  My problem is that the leader line does not attch at the corners of the box, rather it seems hit at the center line of the overall geometry.  So it doesn't attach to the tag directly.  Is there a way to control where the leader lines eminates from?
I have attched the tag for clarity.
Mon, Jan 2, 2012 at 10:46:01 AM | Manipulating the Leader Line
TKennedy
4 Stars: 7 Votes
As far as I can tell, no.
Mon, Jan 2, 2012 at 11:02:57 AM | Manipulating the Leader Line
rwelliot3
Dang, I was affraid of that being the case.  Thanks for your help.  How can I suggest that for an option of the next version?
Mon, Jan 2, 2012 at 11:05:14 AM | Manipulating the Leader Line
TKennedy
4 Stars: 7 Votes
There is a wishlist forum here. You might want to check if there is an existing post, if there is just bump that.
Adding Snaps to Leader Lines
Thu, May 29, 2014 at 7:34:34 AM
Callout Leader Line Straightening After Placing
Fri, Jan 22, 2016 at 3:36:22 PM
leader note line
Wed, Aug 22, 2012 at 2:18:01 PM
Leader Line Line weights
Sat, Feb 7, 2009 at 10:47:57 AM
Positioning the leader on a tag.
Thu, Aug 6, 2015 at 12:16:39 PM
Page generation time: 0.8143
