7 Posts No Rating |
Com ajuda de alguns amigos, como estudo, consegui criar uma família tipo Metric Generic Model line based, mas gostaria de controlar a quantidade de objetos de acordo com que eu for esticando a linha. Não consigo entender como faço isso. Poderiam ajudar-me?
Desde já, agradeço-lhes pela ajuda.
Abraços e feliz 2012.
With the help of some friends, and study, able to create a family type Metric Generic Model linebased, but would like to control the amount of objects according to what I'm stretching the line. I can not understand how to do it. Could you help me? We thank them for their help. Hugs and happy 2012.
Note: I used the google translator
There are many posts on Revitcity about this.
You need to make sure that you have a length parameter that changes to over all length of the object. Then when you are creating your array make it so that it fits the size you are currently working with. Once the array is done click on the line that same way you do with the dimensions and make it a label. and in the formula field add this
ArrayNum = Length( This being the name of the original parameter)/Spacing( how many per length)
This can get confusing and it will take a little trail and error to figure it out. Try finding a family that has a simular parameter in it to see how it behaves.
