81 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Rebar in a thickened slab Revit 2012
Wed, Dec 28, 2011 at 2:18:13 PM | Rebar in a thickened slab Revit 2012
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I have created a slab and I have added the profile to create a thickened slab.  I can add rebar to the slab but not to the thickened profile portion.  I know the slab needs to be changed to structural to allow the rebar to read it but how can I get the thickened slab to respond to it also?
Thu, Dec 29, 2011 at 6:40:30 AM | Rebar in a thickened slab Revit 2012
gprakash
Revit Structure allows Rebar to add in a 'Slab Edge'. Not sure how it behaves if you are using Revit Architecture.
Optionally, try placing Rebar at Slab area and then move the rebar to thickening area and modify as required.
Thickened Slab Not Cutting Floor Line Out
Wed, Dec 28, 2011 at 7:54:14 AM
Thickened slab appearance
Fri, Jun 8, 2012 at 10:43:24 AM
Thickened slab at stoops
Sun, Sep 25, 2005 at 6:39:42 PM
Modeling thickened slab strip under bearing walls
Thu, Feb 5, 2015 at 1:13:01 PM
Thickened Slab Edge on Sloping Slabs
Thu, Apr 16, 2009 at 3:39:09 PM
Page generation time: 2.1884
