139 Users Online (137 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Instance Parameters in titleblock not linking
Fri, Dec 23, 2011 at 10:50:20 AM | Instance Parameters in titleblock not linking
ml22
Using Revit Architecure 2012:
We have a standard titleblock with shared parameters for most of the information, and it's working fine in most of my projects.  I have one project where none of the parameters seems to be linking.  I've tried removing and re-adding the parameters, and deleting and reloading the titleblock family, without success.
What could be wrong?
Fri, Dec 23, 2011 at 10:54:34 AM | Instance Parameters in titleblock not linking
Are they really the same shared parameters?  Name doesn't mean anything.  I would make sure they are.
Fri, Dec 23, 2011 at 11:33:11 AM | Instance Parameters in titleblock not linking
ml22
Shared Parameters > Edit Shared Parameters > Shared parameter file: lists the same file in the same location as the file listed in the projects where everything works.  Anything else to check?
Fri, Dec 23, 2011 at 11:45:42 AM | Instance Parameters in titleblock not linking
That doesn't mean it is the same file.  That is just the current shared parameter file you are using.
Just a simple test.  Try a new file using your template - this titleblock and your titleblock that works in other files.
Fri, Dec 23, 2011 at 11:52:16 AM | Instance Parameters in titleblock not linking
I just thought some more about what you are doing.
How is your titleblock created?  The shared parameter is not loaded as a parameter.  You simple add a label that points to your shared parameter file.  Look at the titleblock that works and see if your new one is built the same.
Fri, Dec 23, 2011 at 12:23:01 PM | Instance Parameters in titleblock not linking
ml22
The titleblocks are the same between projects.  To be sure, I could open a project where the TB works, open the TB with the family editor, and load it into my problem project, right?
Fri, Dec 23, 2011 at 1:00:40 PM | Instance Parameters in titleblock not linking
That might answer the question and might not.  That is why I wanted you to use a new project.  To see if both titleblocks worked in it.  Give them different names even if they are the same.  Trying to verify that your project parameters match your titleblock ones.
Fri, Dec 23, 2011 at 2:35:13 PM | Instance Parameters in titleblock not linking
ml22
The problematic TB did not pick up the parameter values in the test project.
Neither did the TB from the project where everything works fine.
What does that mean?
Sat, Dec 24, 2011 at 8:26:34 AM | Instance Parameters in titleblock not linking
How did you set the project parameters in this project.   Obvously something is wrong with your template.  Its parameters are not the same.  You need to get both your project and your titleblock using the same parameters.  Again - as I said, name doesn't mean they are the same.
Wed, Dec 28, 2011 at 9:54:28 AM | Instance Parameters in titleblock not linking
ml22
How do I get them using the same parameters?  I've tried deleting the old ones and loading new from the shared parameter file.  What am I doing wrong?
Wed, Dec 28, 2011 at 10:05:08 AM | Instance Parameters in titleblock not linking
Read this topic in your HELP:>   Exporting Shared Parameters to a Shared Parameter File
Also read this:>  Viewing, Moving, and Deleting Shared Parameters
Wed, Dec 28, 2011 at 10:21:07 AM | Instance Parameters in titleblock not linking
ml22
Thanks for the reply.  In the meantime I've unloaded and reloaded the parameters from both the project and the family, and they're working again.  Pain in the A, though.  Still don't know why they un-linked in the first place.
Wed, Dec 28, 2011 at 10:31:23 AM | Instance Parameters in titleblock not linking
#13
They didn't unlink, the problem is somewhere in your process.  I suggest you read the Help files I posted.  This issue is confusing to many new users.
Drawn By and Checked By titleblock parameters
Fri, Oct 10, 2008 at 10:43:12 PM
Titleblock Parameters [ 1 2 ]
Thu, Mar 13, 2014 at 4:57:53 PM
17
How to link shared family parameters into an assembly titleblock?
Mon, Apr 20, 2015 at 8:14:15 AM
Title Block Specific Parameters
Mon, Jun 20, 2011 at 7:15:37 AM
Project Information Parameters
Tue, Jul 27, 2010 at 5:31:45 PM
Page generation time: 0.7774
