61 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> REVIT MEP 2012 WIRING - EDIT WIRE FAMILY
Wed, Dec 21, 2011 at 2:54:01 PM | REVIT MEP 2012 WIRING - EDIT WIRE FAMILY
Agile3100
I was wondering if there is a way to edit the wire family in Revit MEP 2012, or is it just a built in family that is non editable?
Tue, Jan 3, 2012 at 3:06:00 PM | REVIT MEP 2012 WIRING - EDIT WIRE FAMILY
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
Built in, what are you trying to change?
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Wed, Jan 4, 2012 at 6:07:45 AM | REVIT MEP 2012 WIRING - EDIT WIRE FAMILY
Agile3100
I wanted to change the arrowhead used for the homerun, also wanted to add parameters to add more homeruns off of the first. I had a feeling that it was non editable though
actually showing low voltage wiring in the model, is it possible?
Wed, Jul 22, 2009 at 3:16:02 PM
Low voltage wiring in Revit MEP
Fri, Apr 23, 2010 at 4:34:26 PM
Multi-wire homerun tag out of order
Fri, Dec 9, 2011 at 10:18:57 AM
Labeling wiring runs with panel name
Mon, Jul 14, 2008 at 9:47:52 AM
Electrical wiring
Wed, Nov 12, 2008 at 4:22:36 AM
Page generation time: 4.2727
