52 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rendering Plants
Fri, Dec 9, 2005 at 11:12:11 AM | Rendering Plants
lwasden
Hi. I am rendering a courtyard pergola with planters. For some reason a few of my plants are not showing up on the render. They are there in every other view. They are in the correct laces and heights. They just aren't rendering. And I am using the exact same plants that are rendering in the same view in other spots. I have tried changing my view and a few one of the invisible plants showed up, but some still dont. Its FREAKING me out! Anyone else have these issues?
Tue, Jan 2, 2007 at 3:00:15 PM | Rendering Plants
Ace001
Did you ever solve this problem? I'm having the same problem. My plants aren't showing up in the renders. How did you fix it?
Thanks
Fri, Jun 15, 2007 at 11:23:37 AM | Rendering Plants
ebtaylor
3 Stars: 2 Votes
same problem here?
anyone, using Revit 2008
Thu, Nov 6, 2008 at 3:26:38 PM | Rendering Plants
mpshannon
You just have to go into the emlement proporties, then edit new and rerout the RPC image to the right file.  FOr some reason it losses track of these RPC files and has to be reasigned.
Fri, Jul 15, 2016 at 2:32:08 PM | Rendering Plants
awittwer
I'm having the same problem.  The rerouting option did not fix it.  If I copy a bush that is showing up it seems to work, but it is very wierd.
Rendering more realistic grass and plants?
Tue, Dec 21, 2010 at 11:19:07 AM
How to edit Accurender plants???
Mon, Aug 16, 2004 at 4:03:09 AM
Revit Plants
Tue, Jul 19, 2016 at 3:55:15 PM
Australian Plants
Wed, Dec 3, 2008 at 8:02:14 PM
Plants
Wed, Jun 14, 2006 at 1:38:02 PM
Page generation time: 0.3939
