Forums >> Revit Building >> Technical Support >> Ceiling grid rotates when mirrored, lights fixtures don't.
19 Posts No Rating |
Using Revit Architecture 12.
When I mirror a 2x4 ACT ceiling, the grid rotates 90°, but the 2x4 light fixtures do not. If I rotate the grid 90° to get it back to where it should be, the lights rotate with it and are wrong. Mirroring is being done on one ceiling grid axis (not 45° to the grid, etc.) Anyone had this happen? Did you find a solution?
Thanks,
Matt
Try grouping the ceiling & light fixtures before mirroring. If it doesn't work, mirror ceiling & light fixtures separately.
Motto: "No Post left behind" |
mhans,
Grouping worked. Great idea. Thanks for the tip.
matt
Welcome. Merry Christmas.
ceiling grids through lighting fixtures |
Wed, Jan 18, 2017 at 2:32:53 PM
14
Ceiling Lights don't self-illuminate |
Mon, Oct 17, 2011 at 10:21:45 AM
Lights in Ceiling Grid |
Sat, Feb 4, 2006 at 12:49:44 PM
Light fittings in ceiling grid |
Tue, Feb 8, 2005 at 6:33:50 PM
rendering ceiling grid |
Wed, May 16, 2007 at 1:37:32 PM
Members: | 2101368 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
