Forums >> Revit Building >> Technical Support >> Electrical plan
41 Posts No Rating |
Using Revit 2011. I would like to know a simple way to import my cad electrical symbols into my electrical plan as detail components so that they only appear on this sheet.
Carl
Do you want them as detail components or symbols? Detail components scale with the view where symbols always print the same paper space size. Either way, you will want to create families for these. BTW - You should find some of these already in your library.
Detail components.I can make a family including all my symbols at one time but I don't know any way to explode this whole family so I can use the individual sysbols.
You can't do them all in one family. You should
- load the cad dwg into your family,
- trace over one of them with Revit linework,
- delete the cad import
- and save the family.
- Then repeat for the next symbol.
This works but I didn't need to trace the objects.
Is there any way to add text to the symbol, like SD, for smoke detector and have it import with the whole element into the drawing?
add a label in the family editor
Combined Electrical and Lighting Plan |
Mon, May 19, 2008 at 2:29:01 PM
Electrical Plan |
Thu, Oct 26, 2006 at 11:38:04 AM
Electrical/Lighting plan [ 1 2 ] |
Wed, May 13, 2009 at 11:27:52 PM
16
Electrical Symbol Overlap in Plan |
Mon, Sep 16, 2013 at 8:50:29 AM
Electrical fixtures in plan |
Mon, Nov 1, 2004 at 3:57:03 PM
Members: | 2098650 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
