59 Users Online (58 Members):
Forums >> Revit Structure >> Technical Support >> Footings, getting double hidden lines and intersections suck!
5 Posts No Rating |
Vent first, I hate the fact that Revit is a program that is not at all user friendly and tries poorly to do the thinking for us. Ttying to lean a new program can be a task already but having to trick this POS all the time into making things work is a eating at me.
My problem.
First, my L shaped footings are coming up with double hidden lines on each side that end up looking like a solid line most of the time.
Second, the footing intersections with other footings and pad footings are not clean. How do i make the intersecting lines disappear?
Thanks in advance!!
![3 Stars: 10 Votes](/images/stars_3.gif) |
Can you post a screenshot? Check the drawing scale and detail level. For footings to clean up automatically, they have to be placed on the same level.
2 Posts No Rating |
I have the same problem with double hidden lines looking like solid lines. This tends to happen when footings intersect with different thicknesses.
2 Posts No Rating |
Sorry trying to attach a screen shot. My jpeg will not load
Edited on: Thu, Dec 22, 2011 at 8:20:11 AM
1 Posts No Rating |
In the VG under Structural Foundations uncheck 'hidden'. See if this will work for you
"Double" lines in view range beyond |
Fri, May 17, 2019 at 12:34:14 PM
Show Hidden Lines Creating Double Lines |
Mon, Sep 23, 2013 at 11:55:16 AM
hidden line view intersections |
Mon, Nov 8, 2004 at 7:58:14 PM
hidden lines below grade |
Mon, Oct 1, 2007 at 2:19:41 PM
Beam/Beam Intersections of Multiple Depths - Hidden lines? |
Fri, Mar 23, 2007 at 1:23:59 PM
Members: | 2022252 | Objects: | 22975 | Forum Posts: | 152202 | Job Listings: | 3 |
