43 Users Online (41 Members):
Forums >> Revit Building >> Technical Support >> Problems with Extrusion depths and position in family with Arrayed Elements
136 Posts No Rating |
Hi all,
As my post suggests I've created the attached family, it seems to work perfect in front elevation when i alter the number of mullions horizontally and vertically, the problem comes when i try to edit the depths of the mullions or position the offset of the whole door from the wall centreline. (please have a play with it and you'll see what i mean, it's as if it moves only one part of the array e.g. the top or the bottom meaning that the array then tilts backward or forward rather than staying vertical as expected.
Please can somebody help me solve this problem? much appreciated for any help.
For Architectural Services visit www.jrpcad.co.uk |
Arrayed Array |
Thu, Oct 7, 2010 at 5:20:21 PM
How can I make a wall with attached elements on it? |
Fri, Oct 22, 2021 at 7:01:19 AM
re-joining (?) cut extrusion with extrusion |
Tue, Apr 17, 2007 at 10:26:27 PM
dynamic arrays |
Wed, Jan 7, 2004 at 12:39:22 PM
Void Sweep won't cut extrusion |
Fri, Aug 24, 2012 at 3:02:42 PM
Members: | 2022391 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
