98 Users Online (97 Members):
Forums >> Revit Building >> Technical Support >> Demo Door/New Wall
![3 Stars: 1 Votes](/images/stars_3.gif) |
When I demo a door, Revit places an in-fill wall in the opening. How can I demo the door while keeping the opening? I know I can change the structure of the in-fill wall. Has someone tried creating a wall that is invisible?
Post edited on 2005-12-08 19:34:26
It looks like you can assign an invisible material to an infill wall. It seems to me that there should just be a way in Revit to turn off the in-fill option on a demo'd door.
![latemore Avatar](user_avatar/6368.jpg)
![3 Stars: 2 Votes](/images/stars_3.gif) |
i understand your problem - but have you tried simply inserting an opening, same size, same place in new phase? may not show up the way you want in all views i guess.
8 Posts No Rating |
Demo Door, then insert an opening into the new wall revit creates.
Thought of that. When I try it I get an error message "Opening completely removes its host"
33 Posts No Rating |
I agree the way Revit handles demo/replace needs some help. The way to get around it is by editing the profile of the existing wall around the door (and make the opening any larger if the new opening is to be enlarged in the process) and assigning it to the existing phase. Insert a chunk of wall that is the size of the new and improved "opening" that was cut out in the edit profile and insert the door in this piece of wall. Demo them both and ... Now the existing wall should remain throughout, the door and any associated wall will show up in the demo phase, and the opening will appear in the completed building phase.
Not great, but it works.
Demo door, make cased opening, no fill in wall |
Fri, Mar 23, 2012 at 12:34:24 PM
new door in exisiting wall |
Wed, Jan 9, 2008 at 4:40:50 PM
Demo Door Automatic new wall |
Thu, Oct 4, 2007 at 10:20:29 AM
No demo lines with new door in existing wall |
Thu, May 7, 2009 at 2:24:45 PM
Revit 2011-Putting a door on Demo but keeping the opening in the wall? |
Wed, Sep 7, 2011 at 2:29:20 PM
Members: | 2017072 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
