31 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Trouble with wall & steel column intersection and joist placement.
Tue, Dec 13, 2011 at 8:32:18 AM | Trouble with wall & steel column intersection and joist placement.
gmcarch
This is my first revit project, and it's been a bit of a crash course so far.  I have 2 issues that are hindering my progress:
1.  How do I put a break in a part of the wall?  As the first picture shows, I have a steel column inside a wall, but the stud is running through it.  Is there a way to break it partially, where the stud ends on each side of the column? This problem is also apparent in section view as shown in the other pictures.  I'd like to do this without using a different wall type.  Before, I just made a wall type with brick, airspace, and sheathing, but I find that this is unacceptable.
2.  I am having issues placing a joist. No matter what I put in properties, I cannot get the joist to rest on the beam, what I have shown is the highest it will let me put it and if I try to manually move it, I get the error as shown in picture 3.
Thanks
Fri, Dec 16, 2011 at 9:34:11 AM | Trouble with wall & steel column intersection and joist placement.
gmcarch
Bumping thread... Anyone?
Double Sloped Steel Joist
Thu, Dec 23, 2010 at 8:35:13 AM
Lineweight of steel column in coarse view
Fri, Jan 7, 2011 at 6:25:48 PM
open web steel joist
Wed, Sep 26, 2012 at 3:09:27 PM
Flushed Wall & Column
Thu, Sep 6, 2007 at 11:19:18 AM
curtain wall at column
Tue, Sep 8, 2009 at 12:24:40 PM
Page generation time: 1.8820
