55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Aligned Dimensions Shift While Moved
Sun, Dec 11, 2011 at 9:25:45 AM | Aligned Dimensions Shift While Moved
nematsvehclav
5 Stars: 2 Votes
http://youtu.be/07GXfzCGijM
How is it possible that I place an aligned dimension between two paralel grids and the dimensions changes as I drag it up and down? First of all, in order to be able to place an aligned dimensions the objects have to be absolutely paralel to each other, so I don't get why when I move the dimension it changes. If the grids were really not paralel to each other Revit shouldn't allow me to place the aligned dimension in the first place, isn't that right?
Mon, Dec 12, 2011 at 7:07:15 AM | Aligned Dimensions Shift While Moved
3.5 Stars: 395 Votes
Revit will not do this for parallel objects.  But you can use an aligned dimension to "points" and that is what I believe you have done.  To select a point instead of a line, you use the tab key.
Mon, Dec 12, 2011 at 7:12:45 AM | Aligned Dimensions Shift While Moved
nematsvehclav
5 Stars: 2 Votes
Yes, I know you use the tab key to select a point but that is not what I'm doing in that instance. I even tried islating only those two grids (which I am not showing in the video actually) and dimensioning explicitly between them and AGAIN I got this weird problem...
Mon, Dec 12, 2011 at 7:59:06 AM | Aligned Dimensions Shift While Moved
What are your dimension units and rounding?
Mon, Dec 12, 2011 at 9:27:16 AM | Aligned Dimensions Shift While Moved
nematsvehclav
5 Stars: 2 Votes
Everything is pretty normal with my units. The same problem occured later on again with some more grids and my workaround this is to align them to each other and them space them again as desired. Nevermind that, the issue in the video is pretty weird.
Project Units:
Discipline Common
Length Format Millimiters
Rounding 3 Decimal Places
Unit symbol None
Suppress trailing 0's Checked
See attachment if necessary. Nothing unusual. The problem doesn't occur with anything else though. Just with grids and it happened just a few times. Just don't get why it even happened.
Mon, Dec 12, 2011 at 11:31:06 AM | Aligned Dimensions Shift While Moved
I did watch the vid and that is strange.  Maybe the program is corrupted.
Mon, Dec 12, 2011 at 11:54:40 AM | Aligned Dimensions Shift While Moved
nematsvehclav
5 Stars: 2 Votes
Well the clip doesn't show anything else than what I initially described. And about being corrupt... well, it's licensed as a student version, so I think it's legal enough. Anyway, we'd better drop all this as it's doesn't matter anymore and is a problem that doesn't have a logical explanation...
Mon, Dec 12, 2011 at 12:33:13 PM | Aligned Dimensions Shift While Moved
4 Stars: 201 Votes
Very wierd, I never saw nothing like that, did you installed the Web Update for 2012?
Mon, Dec 12, 2011 at 12:39:45 PM | Aligned Dimensions Shift While Moved
nematsvehclav
5 Stars: 2 Votes
Very weird indeed. The impossible seemed possible.
Ermm, Web update? What do you mean by Web? I currently have the latest Update 2 for Revit and the Build is 20110916_2132(x64) Update Release 2.
Is there anything newer out there? Have I missed something? If so, please share a link.
Mon, Dec 12, 2011 at 12:43:41 PM | Aligned Dimensions Shift While Moved
4 Stars: 201 Votes
"the Build is 20110916_2132(x64) Update Release 2." - that's the latest update.
Aligned dimensions on non-orthogonal walls
Sun, Jun 11, 2006 at 8:16:11 PM
Aligned dimensions for centering curtain wall door
Fri, Dec 23, 2011 at 6:26:40 AM
aligned acting like linear (up-down, left-right)
Tue, Dec 6, 2011 at 4:00:40 PM
Aligned dimensions
Wed, Apr 12, 2006 at 3:22:31 PM
Ctril and Shift not working
Mon, Jan 20, 2014 at 12:52:49 PM
Page generation time: 1.7960
