94 Users Online (97 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Elevation markers
Sun, Dec 11, 2011 at 8:31:19 AM | Elevation markers
idraw38
I use Revit 2011. I asked this question a week ago with no response. I am wondering why my elevations markers have in part disappeared. All I can see is some letters and numbers but no pointer. Help!
Carl
Mon, Dec 12, 2011 at 7:05:16 AM | Elevation markers
You mean the elevation callout?  Be clear when you use the term elevation because it has several meanings.
It sounds like you have hidden the pointer maybe?  Use the lightbulb to reveal hidden items.
Mon, Dec 12, 2011 at 8:01:56 PM | Elevation markers
idraw38
It is the elevation view markers, the ones with the arrow, that are the problem. There are no hidden elements and clicking the light bulb doesn't help. There are no unchecked items in VG. The only thing I see is a number where the arrow would normally be and something like A6, A7 where the square would be. Maybe this helps.
Thanks
Carl
Tue, Dec 13, 2011 at 7:25:25 AM | Elevation markers
If you are using the standard elevation callout and not one that someone else created or modified, then maybe your program or file is corrupted.
As a test, start a new project, create some elevation views and place them on sheets to see what happens with the callout.
elevation markers disapeared
Wed, Jan 13, 2010 at 3:59:29 AM
Elevation markers
Thu, Oct 19, 2006 at 11:46:46 AM
Scaling section and elevation markers
Thu, Jul 26, 2012 at 7:13:35 AM
Elevation Markers, Level Heads, Section Markers, all at Varing Scales
Mon, Feb 20, 2012 at 11:33:58 AM
Revit 2013 - Missing Elevation Markers
Fri, Feb 22, 2013 at 7:14:49 AM
Page generation time: 11.8110
