111 Users Online (110 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> PDF Quality?
Fri, Dec 9, 2011 at 11:23:02 AM | PDF Quality?
davidlowery
Does anyone have anything to offer about PDF quality on Revit projects?  I have a very strange thing happening here.  Some of the beams in plan view look very grainy or pixelated, some don't.  In many cases, there are beams side by side that are the same member size, same slope - virtually identical - yet they look different on the PDF.
I am using Revit Structure 2012 and Abobe Acrobat or Primo PDF.  Same problem occurs with either program.  I have tried the dpi settings, raster, vector, everything I can and the prints look like virtual crap.
Fri, Dec 9, 2011 at 11:41:11 AM | PDF Quality?
3.5 Stars: 395 Votes
If an element is at an angle, it will often become pixalated.  Also if it is a different color from black.
Fri, Dec 9, 2011 at 11:49:22 AM | PDF Quality?
davidlowery
So we can't have sloping beams or they will look horrible?  I was afraid of that.  However, I have some sloping beams that look just fine - and every beam is black.
Fri, Dec 9, 2011 at 12:01:55 PM | PDF Quality?
If you are forced into raster printing because of a shaded object, you have this problem with angled objects.  It is not a Revit issue.  It is a PDF issue.  See if you can print vector instead of raster.
If you are in a plan view and the beam is angled vertically, then this is not your issue.  The angled problem is angled in plan.  I would check and make sure their are no over-rides on this element in both by element or phase.
Fri, Dec 9, 2011 at 12:16:09 PM | PDF Quality?
davidlowery
Yeah.  The problem is that the PDF's look really bad and I have tried for years really to solve these problems to no avail.  Thanks for the help, but I think Autodesk needs to address this one.  I can make PDF's from AutoCAD all day long with no problems ever, but with Revit I get problems every time.
Physical Print Quality of PDF's Produced from Revit
Tue, Apr 23, 2013 at 9:49:54 AM
How to copy high quality Elevation view to image file
Wed, Apr 20, 2016 at 7:09:36 AM
importing quality jpgs or pdfs
Sun, Oct 30, 2005 at 6:48:09 PM
Pdf Output
Wed, Feb 18, 2015 at 7:19:54 PM
Printing Shaded Elevations to PDF
Wed, Oct 19, 2011 at 11:23:07 PM
Page generation time: 0.4515
