84 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> walls covering pipes
Fri, Dec 9, 2011 at 8:00:28 AM | walls covering pipes
zonker
doing plumbing plans in MEP and the walls are covering the pipes. anyway to control that?
Tue, Dec 13, 2011 at 11:36:09 AM | walls covering pipes
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
are you working in the architectural file or is it linked? if linked try changing the visual style. if you are working the architecture, you will need to most likely start over. Are you able to post an image?
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Duo pipes - Twin pipes for central heating
Wed, Jan 16, 2019 at 3:48:53 PM
Can we convert lines to pipes? (Revit MEP)
Tue, Aug 28, 2007 at 9:26:18 AM
REVIT MEP 2012 Demo Phasing Disconnecting Pipes
Wed, Jul 18, 2012 at 12:20:02 PM
Pipes display as solid in section
Thu, Apr 25, 2013 at 9:27:41 AM
Side Covering
Fri, Nov 2, 2012 at 2:52:35 PM
Page generation time: 0.6769
