75 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Level Shared Parameter
Wed, Dec 7, 2011 at 8:34:46 AM | Level Shared Parameter
cundall
Does anybody know if theres a way to make a level shared parameter in plan (see attachment)
I have been using text to call up a beam level in plan.  the problem with text is that if the beam changes level the text wont.
just want to know how you guys call up beam levels in plan and also if there is a way of making a level shared parameter in plan ???
regards
Wed, Dec 7, 2011 at 8:48:53 AM | Level Shared Parameter
Doesn't a spot elevation tag work here?  You can create one that doesn't have the target.
Wed, Dec 7, 2011 at 8:52:22 AM | Level Shared Parameter
cundall
I dont know, thats why ive come on here asking how you guys do it. is that the prefered method using a spot elevation without the target ?
Wed, Dec 7, 2011 at 9:11:52 AM | Level Shared Parameter
cundall
If i was to make a spot elevation without the target is there a way to make it Orientate the same way has the beam ? just like a framing tag would ?
regards
Wed, Dec 7, 2011 at 4:26:55 PM | Level Shared Parameter
Manny
3.5 Stars: 6 Votes
MODIFY YOUR STRUCTURAL TAG AND ADD "START LEVEL OFFSET"
Thu, Dec 8, 2011 at 3:01:30 AM | Level Shared Parameter
cundall
but that just gives me the offset of the level, i want the spot elevation call up
regards
Cannot Locate SHARED PARAMETER FILE!
Tue, Oct 7, 2008 at 3:16:48 PM
Shared Material Between Families
Mon, Aug 31, 2015 at 11:21:40 AM
Referencing a Shared Parameter in a Family parameter formula.
Thu, Jan 29, 2015 at 1:26:24 PM
Instance Shared Parameter??
Fri, Jul 11, 2014 at 2:49:26 PM
Add Family name to a shared parameter
Tue, Jun 23, 2015 at 8:50:48 AM
Page generation time: 0.8683
