51 Users Online (48 Members):
Forums >> Revit Systems >> Technical Support >> can't "reach" pipes (revit MEP)
5 Posts No Rating |
I have linked an revit architecture file into revit MEP. I set the view range to desired amount, draw some pipes (below the surface so to speak), the pipes pop up, everything shows. But I can't click them. If I drag the linked scheme away from the pipes, everythings's fine. It's almost like the linked file is on top of everything and therefor I can't work properly.
For the record, I'm a student and therefor a beginner at Revit.
Best regards
What I am going to assume is that your view is set to hidden line or above, switch it to wireframe and you will be able to select the piping.
hth
http://familyjewels.typepad.com/ |
23 Posts No Rating |
Yes switch to wireframe...its a good idea to 'pin' your model just incase you accidentally shift it while trying to click on the pipework ;-)
5 Posts No Rating |
That did the trick =)
Great forum, thanks!
Regards
NEED HELP with Revit MEP - pipes obscured by connector "halo" on plan views |
Tue, Jul 14, 2009 at 10:02:59 AM
"can't change dimension segment to this value" error 2013 pipes |
Thu, Oct 18, 2012 at 7:56:04 AM
Connecting 3 Pipes |
Mon, Jun 28, 2010 at 11:25:05 AM
Can we convert lines to pipes? (Revit MEP) |
Tue, Aug 28, 2007 at 9:26:18 AM
REVIT MEP 2012 Demo Phasing Disconnecting Pipes |
Wed, Jul 18, 2012 at 12:20:02 PM
Members: | 2056698 | Objects: | 23074 | Forum Posts: | 152327 | Job Listings: | 3 |
