Forums >> Revit Building >> Technical Support >> Modelling stairs and balustrades by level.
First post
When a model is split into files by level and the stairs are modelled in each file, floor to ceiling for that level only, how can the balustrades most efficiently be modelled at each level, should the balustrades be broken at each flight, or at each scissor stair and should the balustrades be segmented centred on goings of a stair run/flight where a baluster needs to be seen.
To control balusters precisely or do the balustrades require breaking at these points.
Franky "D" Halliday
Edited on: Sun, Dec 4, 2011 at 5:39:29 AM
Dr. Zaius: Ah, yes - the young ape with a shovel. I hear you're planning another archeological expedition. Cornelius, a friendly word of warning - as you dig for artifacts, be sure you don't bury your reputation. |
BTW,
How can you align the breaks in the balustrading sketches. In plan these appear to work nicely, however they don't align after getting out of sketch mode. The sketch line appears neither centred, left or right justified.
DON'T DO SEPERATE FILES!!
Can you be specific why we shouldn't separate into files level by level? What pitfalls do you predict WWWhub?
that sounds like some architectural desktop workflow. never heard of anyone doing that in revit. if you are worried about model size autodesk has published a white paper about model management.
Where can I find this edict from Autodesk? DOES IT SCALE? You know we are creating a pretty f!@#$n huge model. it's 10 levels at 150-250 x 100-150 m floor plates approx. Further the model is full of fit-out. Yet I am wondering... maybe cris price knows?
Glass balustrades on stairs |
Fri, Sep 7, 2007 at 3:07:11 AM
When to model stairs by level or as a vertical model? |
Sun, Feb 19, 2012 at 2:03:43 AM
stairs! stairs! STAIRS! help! |
Fri, Mar 20, 2009 at 4:34:04 PM
stairs not connecting to landing- see attachment please! |
Mon, Mar 5, 2012 at 12:29:45 PM
cut symbol on stairs |
Sun, Dec 4, 2011 at 8:21:55 AM
Members: | 2056537 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
