44 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> Floorqwall cutting lines - heavy lines at core
28 Posts No Rating |
I would like the heavy line of a wall or floor to go along the core outline only, and not along other materials (finish, etc.), so for example if i have a floor of 4' concrete, 3' space and 1' flooring, the cut line will show only around the concrete area.
Thanks for any help
21 Posts No Rating |
Discussed a couple of days earlier - Mr Spot posted solution using overrides
http://www.revitcity.com/forums.php?action=viewthread&thread_id=2541
Over rides are a workaround however, and should really not be necessary if through object styles you could define the line weight of layer types of walls/roofs etc
This is a problem of revit - control and access to dimensional information of each of the individual layers of walls and floors is not yet good enough. There is fantastic potential here to automate the interaction of host based objects (sweeps, windows etc) once access to wall /floor/ceiling layer host information is available to families to interact with.
C
Hid Lines deplicting finishes on walls in plan view to see the core lines only |
Sat, May 15, 2010 at 5:49:20 AM
My bump lines are too thick and heavy. [ 1 2 ] |
Thu, Aug 11, 2016 at 2:45:38 PM
21
Lines too heavy in perspective view |
Wed, May 1, 2013 at 6:36:38 PM
Lines in the middle of beams |
Thu, Feb 2, 2006 at 9:09:20 PM
hiding core elements in a wall section |
Fri, Jun 23, 2006 at 1:07:58 PM
Members: | 2056530 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
