111 Users Online (110 Members):
Forums >> Revit Building >> Technical Support >> How would you make a void in a wall, at a corner?
19 Posts No Rating |
Hi,
I need to make a void in a wall, at a corner. How can I do this?
It is essentially a window opening that is at a corner. Any ideas?
Thanks,
Craig
On this topic as well...
How would you make a reveal?
Can you do Boolean operations in Revit? How?
Thanks
Here's your answer Ace:
It's all in the "terminology". Boolean operations are referred to as "cut-outs" and are very easy if you look in Help. Reveals are also described in Help.
Isn't this forum helpful.
Thanks.
You're welcome.
Let's have lunch now.
OK.
2 Posts No Rating |
LOL
ACE playing the ventriqulist... ![Winking](/images/smiles/wink.gif)
admin
![hjacobs Avatar](user_avatar/2.jpg)
![3.5 Stars: 16 Votes](/images/stars_3.5.gif) |
Hola,
wasn't sure if you were able to get your questions answered completely. You can modify a wall and put any kind of void you want in it by clicking on it and selecting "edit elevation profile" at the top. You will need to go to an elevation view of the wall and draw the hole you want. As far as reveals go, you can add one in the wall's type properties or use the "host sweep" tool on the modelling tab. Did you have a more specific question on reveals? You might have figured all this out already, but if not, I hope this was helpful.
-Hiroshi-
Corner guards to snap to corner of wall |
Tue, May 13, 2014 at 12:18:44 PM
Void Etrusion not working when I load family |
Tue, Apr 28, 2009 at 2:27:58 PM
VOID form will NOT work! [ 1 2 ] |
Mon, Jan 30, 2012 at 3:00:24 PM
22
Make void extrusion permanent |
Wed, Feb 9, 2022 at 6:46:57 PM
How to build a butt joint corner window family? |
Thu, Mar 27, 2008 at 12:21:14 PM
Members: | 2017156 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
