46 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> base plate visibility problem
Thu, Dec 1, 2011 at 8:31:40 AM | base plate visibility problem
seniorcad143
1 Stars: 1 Votes
My bas plate show up in section only if I have the wireframe set, but hen my columns shows up solid.
If I have it set to hidden my column shows up right but my base plate doesn't show up at all.
How can I fix this? (The column and base plate are both beyond)
Yeesh - Where is My Cad
Thu, Dec 1, 2011 at 12:34:34 PM | base plate visibility problem
jterrell
3 Stars: 5 Votes
Change the column visibility to transparent by overriding the graphics for the column.
Column Base Plate Nested Family - GCS Visibility
Sat, Feb 21, 2009 at 9:18:00 AM
Column base plate tag units display.
Mon, Nov 17, 2014 at 2:24:41 PM
Revit 2010 Extensions - Column Base Plate
Thu, Oct 7, 2010 at 1:44:48 PM
Attaching a footing to a column with a base plate nested into the footing family
Thu, Jul 11, 2019 at 12:23:43 PM
Base Plates & Graphical Column Schedules
Mon, Feb 22, 2010 at 11:51:02 AM
Page generation time: 0.8312
