44 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> hatching foundation walls
Tue, Nov 29, 2011 at 9:12:24 AM | hatching foundation walls
seniorcad143
1 Stars: 1 Votes
is there a way to show concrete walls as shaded and only halftone.  The concrete pattern interferes with the reinforcing and sometimes you can't see the reinforcing (for instance #4 bars) unless you lie about the size of them.
So we would like to shade our concrete walls (that are in section), but only shade them with a halftone.  Is this possible?
Yeesh - Where is My Cad
Wed, Nov 30, 2011 at 12:24:00 PM | hatching foundation walls
LIZARD2806
3.5 Stars: 7 Votes
Any chance you can upload an image of what you are seeing and an image of what you want it to look like?
Wed, Nov 30, 2011 at 1:18:20 PM | hatching foundation walls
jterrell
3 Stars: 5 Votes
If the section is course, change the course scale fille pattern. If not, use filters to change the cut pattern and color.
Wed, Nov 30, 2011 at 3:25:29 PM | hatching foundation walls
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I just use a modified concrete material that has a grey solid cut pattern. Then the rebar sits nicely on top.
This video my help > http://www.youtube.com/watch?v=2fm7kAbFjow
hatching/visibility issue
Wed, Mar 26, 2008 at 3:10:44 PM
Foundation walls in elevation
Sun, May 22, 2005 at 8:46:49 PM
Hatching
Wed, Nov 7, 2012 at 11:02:10 AM
Foundation Walls not mitering?
Fri, Jan 25, 2008 at 9:10:52 AM
hatching line doesn't show in callout views
Thu, Jul 26, 2012 at 7:10:09 AM
Page generation time: 2.7045
