57 Users Online (55 Members):
Forums >> General Discussion >> Revit Project Management >> Axis of floor plan are slightly rotated
Hello
Im working on a big project of academy and one view of floor plan is slightly rotated, it seems to me like the angle of X, Y axis change about 1 or less degree. I really dont get it, dont know where the problem should be.
Thaaanks for help
Having a similar problem in one of our projects and would like to know the best solution.
I've tried drawing a line and measuring the angle and then rotating the crop view accordingly and the view still seems to be rotated by a small degree.
Any thoughts?
We really don't know what you have done. If it is rotated then you did it.
Did you copy/trace CAD? That always can be an issue.
You can rotate the viewport like you have done but that is typically a poor solution unless it is to correct a previous rotation. The rotation is only for that view. If the entire project needs to be rotated, then you need to use the rotate north/project tools as applicable.
If you built the model incorrectly, then I suggest you correct it.
"Line in Sketch is slightly off axis and may cause inaccuracies." |
Thu, Jul 7, 2011 at 6:47:16 PM
Lines slightly off axis |
Thu, Nov 9, 2006 at 1:36:13 PM
walls slightly off axis? |
Thu, Jan 15, 2009 at 5:06:36 PM
Rotated my floor plan |
Thu, Jul 16, 2015 at 10:19:55 AM
Floor levels slightly offset |
Mon, Nov 5, 2012 at 10:23:46 AM
Members: | 2022361 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
