163 Users Online (162 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Workflow & Implementation >> Training >> revit assembly / group ?
Sat, Nov 26, 2011 at 9:11:54 AM | revit assembly / group ?
viktorik
Hi to all, I want to know what I must do with 1 table with 2 chairs if I want to copy them together after that to copy this block manu many times on different levels 100 times and I'd like to not make the ptoject's weight to big or to not decrease to much the performance...  Is there something like x-ref in 3ds max?
thanks!
Sat, Nov 26, 2011 at 10:00:11 AM | revit assembly / group ?
If you used families, that is all you need.  They should not overload the model.
Sat, Nov 26, 2011 at 10:15:07 AM | revit assembly / group ?
viktorik
yes. 3 families, but I made assembly of them is there anithing wrong?, and when I copied them-it said -(Edits caused an assembly to match an existing assembly type and inherit a new name.) file size incrased from 98-to 106mb , If i make group this message dont appear or something like that... so group is better?
Group or Assembly
Wed, Oct 4, 2017 at 3:16:19 AM
Revit Assembly or Group
Mon, May 11, 2015 at 1:42:20 PM
assembly
Mon, Apr 22, 2013 at 5:03:47 AM
Modifying vertical structure in edit assembly
Fri, Feb 9, 2018 at 4:27:21 PM
help scheduling rooms with assembly codes
Thu, Jun 6, 2013 at 11:02:20 AM
Page generation time: 15.2656
