60 Users Online (58 Members):
Forums >> Revit Systems >> Technical Support >> Recessed Can Spotlight does not show through Ceiling?
23 Posts No Rating |
Hi Guys,
I am having trouble with recessed can spotlights in Revit, they apply in the model fine; when I attempt to render the scene they do not appear to be showing.
I have checked the obvious things like if the lights are on in the render section, artificial lights only etc.
I edited the family quickly and noticed that the 'Tube' for the light to pass was a void extrusion, I went to the trouble of extending this further past the reference plane but that didn't even help in them penetrating the ceiling.
Is this an issue with linked files? Do I need to add the fittings to the architectural model and not the MEP system model. I modified the ceiling from 'Compound' to 'Basic' but that didn't change much.
I ended up moving the light source down a little and it has now shown some light, albiet not very nice.
The light obviously does not cut the ceiling and that would be true if the ceiling is in a linked model.
Your a genius, Ill give that a go ;-)
Hmmmm WWhub can you bind in a ceiling from the architectural model? Looks like Im going to have to delete the ceiling plans and start again. :-(
Why not just copy the ceiling into your model and have your lights hosted in it, then turn off the linked files ceiling.
recessed Lighting for a curved ceiling or roof ceiling? |
Fri, Jun 27, 2008 at 11:06:24 AM
Recessed cans in family |
Sat, Jan 14, 2012 at 4:48:35 PM
Can't figure out how to insert Recessed Can lighting into ceiling plan |
Mon, Aug 16, 2010 at 12:50:05 PM
Recessed cans = no light |
Fri, Mar 6, 2009 at 7:41:57 AM
Light Fixture - Recessed |
Fri, Nov 13, 2009 at 9:14:57 AM
Members: | 2022260 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
