53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Earth Hatch
Thu, Nov 24, 2011 at 5:38:25 PM | Earth Hatch
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Hey guys this has been driving me nuts.. the earch hatch in my section the lines are vertical and horizontal. In Australia
we show our earth hatch on a 45ยบ angle how can I edit this to change it.
I click on my topography and hit V V to get the visibility / graphic overides up and then go down to topography
then under Projection / Surface then Patterns I go overide. Then select the earth pattern click edit but it wont let me just
rotate it in custom. If i go to simple it will but it is just single lines then.
Revit 2018........
Thu, Nov 24, 2011 at 6:45:58 PM | Earth Hatch
hugh
3.5 Stars: 4 Votes
Try this:
;%VERSION=3.0
;%UNITS=INCH
*EARTH,Earth (cut)
;%TYPE=DRAFTING
;        Pattern written by HatchKit v2.7 Hatch Pattern Editor
;        HatchKit v2.7 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2008.
;        www.hatchkit.com.au
45,-0.13258,0.13258,0.25,0.25,0.25,-0.25
45,-0.066291,0.066291,0.25,0.25,0.25,-0.25
45,0,0,0.25,0.25,0.25,-0.25
135,0,0.30936,0.25,0.25,0.25,-0.25
135,-0.066291,0.24307,0.25,0.25,0.25,-0.25
135,-0.13258,0.17678,0.25,0.25,0.25,-0.25
Hugh Adamson
www.hatchkit.com.au
Thu, Nov 24, 2011 at 7:02:53 PM | Earth Hatch
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
ohh legend. thanks heaps do I have to over ride the hatch everytime or can I make it the default earth hatch?
also I accidently posted twice pc screwed up..
Revit 2018........
Thu, Nov 24, 2011 at 8:22:41 PM | Earth Hatch
hugh
3.5 Stars: 4 Votes
Don't know. I've not done that but this may be of help:
http://www.revitzone.com/presentation-and-graphics/149-topography-changing-the-section-cut-material
You may need to go further and overwrite the default by loading a new version.
Hugh Adamson
www.hatchkit.com.au
Fri, Nov 25, 2011 at 8:00:03 AM | Earth Hatch
Massing and site tab pull down is where you set this.
Tue, Nov 29, 2011 at 5:23:50 PM | Earth Hatch
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Thanks heaps for that..
Revit 2018........
Earth hatch
Tue, May 13, 2008 at 11:40:00 AM
Show earth hatch in sections, but not in elevations?
Thu, Oct 29, 2015 at 7:45:46 PM
Basement filled with Earth Hatch
Mon, Feb 24, 2014 at 2:04:35 AM
Topo hatch disappear under building pad
Mon, Jan 27, 2014 at 8:27:54 AM
Earth Hatch Pattern
Fri, Mar 10, 2006 at 8:37:49 AM
Page generation time: 0.4043
