45 Users Online (44 Members):
Forums >> Revit Building >> Technical Support >> Topography Scale
86 Posts No Rating |
Hi there,
I've built a topography and set the scale to 1:100. However, when I dimension any of the land, it measures 500 for 5m (instead if 5000). Is there an easy way to change the scale so that the dimensions all correlate properly?
Thanks
Change the "Project Units" I believe you have that in CM (centimeters) and you want that in MM (milimeters) correct?
adding topography not to scale |
Sun, Mar 5, 2006 at 10:28:45 PM
Rendering Elevation 3d views with scale |
Tue, Aug 14, 2012 at 9:43:43 AM
Topo coarse scale fill color |
Fri, Jun 15, 2007 at 10:00:13 AM
TOPOGRAPHY SPLIT PROBLEM |
Mon, Sep 22, 2008 at 2:51:42 PM
Topography |
Wed, Oct 19, 2016 at 6:19:21 AM
Members: | 2017200 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
