39 Users Online (39 Members):
Forums >> Revit Building >> Technical Support >> Lineweights in linked model
Hi,
im having touble figuring out why my lineweights dont show on my linked model,
the model is linked and set in vg as by linked view,
any ideas?
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Sorry but your image doesn't tell us anything and your question is unclear.
VG can control linked models.
Plz follow this picture attached:
first you have to disable the view template for the import catergory.
then you control type VG command and choose the what visibility of object as you want.
hope it helps.
Edited on: Wed, Nov 19, 2014 at 8:57:24 PM
Are the lineweights in the two files different (the acctual lineweight setteings i.e. 1=.001)?
If they are different, I have found a work around for this (haven't tested this in 2015 yet).
http://www.revitcity.com/forums.php?action=viewthread&thread_id=26525
"We have changed the our line wieghts from the OOTB revit wieghts. This is what is causing the issues.
example: the actual line weight for #9 is .0180 in our file. in theirs its is .2. Theres is much larger. just setting the VG to 9 does not work because it reads their file's weight for #9. I could set it to a line weight number closer to ours (their #3 or so) but it would not match exaclty and it is easier (yet still annoying) to just overwrite their file before linking or reloading. The same thing happens with materials. We have our precast conc. set to have no cut pattern but theirs is set to have a concrete hatch. it shows up as a concrete hatch."
Another quick check would be to see if the linked modelis set as an underlay.
Lineweights Issue |
Thu, Nov 17, 2005 at 6:05:35 PM
Revit lineweights |
Wed, Jan 28, 2015 at 9:31:49 AM
Linked Cad File - Lineweights |
Tue, Nov 18, 2014 at 10:20:58 PM
Not able to place room copied from linked model |
Wed, Mar 18, 2015 at 8:10:37 AM
Lineweights Question |
Wed, Aug 3, 2005 at 4:03:11 PM
Members: | 2037258 | Objects: | 23017 | Forum Posts: | 152210 | Job Listings: | 3 |
