62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> View Range :Option Question
Thu, Nov 24, 2011 at 8:53:29 AM | View Range :Option Question
ossosso
Hi!
I've started Revit using the default Italian Template.
There are 2 level (ground floor and first floor).
I've built a really simple square building (4 walls) of 2 floors. I've put some doors in the ground floor and then I've switched
to the next level to insert some window in the first floor.
While I'm in the second level (1st floor) I can see in viewport also the doors of the level below (even if they have a
light grey color and not all black).
My question is: how can see in level 1 only items in level 1 and in level 2 only items in level 2?
Using the "View Range" Option (in level 2 viewport) seems to solve no the problem (setting both parameter "Bottom" and
"View Depth Level" to the hightest level).
It's hard to manage complex project 'cause while I'm on a level above I can accidently select something below. and so on.
Thank you very much.
Thu, Nov 24, 2011 at 9:57:29 AM | View Range :Option Question
4 Stars: 203 Votes
Change the "Underlay" option in that view properties.
Fri, Nov 25, 2011 at 2:14:26 AM | View Range :Option Question
ossosso
Thank you, now it works Smile
view range issues
Tue, Nov 18, 2008 at 5:06:44 PM
view range on uderlay inconsistant with view range of plan view
Thu, Sep 4, 2008 at 3:48:12 PM
question using view range
Mon, Apr 6, 2009 at 1:41:25 PM
Modify the View Range Settings
Fri, Mar 28, 2014 at 8:42:51 PM
view range
Fri, Sep 7, 2007 at 2:28:05 AM
Page generation time: 1.5403
