112 Users Online (110 Members):
Forums >> Revit Structure >> Technical Support >> Tagging Bottom of wall elevations in plan?
15 Posts No Rating |
We typically show a bottom wall eleavtion in our plans. Is there a way to create a tag or spot elevation that will show the actual elevation so I don't have to use the dinosaur method of inputing text?
Thanks
Joseph F
BIM Coordinator |
You need a model element that resides at that elevation for you to tag with an elevation marker.
The wall is a model element? I just need to tag the bottom of it, but it's not available.
Joseph F
BIM Coordinator |
Spot Elevations In Plan |
Mon, Aug 7, 2006 at 5:14:23 PM
Revit door families |
Fri, Jul 18, 2014 at 4:31:44 PM
IS IT POSSIBLE TO SPOT ELEVATIONS OF A WALL IN A FLOOR PLAN? |
Tue, Jan 25, 2011 at 1:25:12 PM
Spot elevations |
Thu, Apr 5, 2007 at 12:01:36 PM
Elevation marks Top and Bottom |
Mon, Apr 20, 2015 at 4:57:40 PM
Members: | 2042307 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
