125 Users Online (123 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit printing issue
Tue, Nov 22, 2011 at 3:31:33 PM | Revit printing issue
streetmike
So I am working on a job with about 20 sheets. When I do a batch plot its seems one or two of these sheets print twice, Once with a really light title block and once with a nice dark title block. I tried printing the sheet by itself and it still prints out the two versions of the sheet.
Revit Structure 2011 64bit
Any Ideas?
Tue, Nov 22, 2011 at 3:57:36 PM | Revit printing issue
Johnzo142
Make sure you deactivate all views prior to printing. Any active views will print twice.
Tue, Nov 22, 2011 at 5:51:27 PM | Revit printing issue
TKennedy
4 Stars: 7 Votes
It's not that open views always plot, the problem is that when you select a number of sheets in the print dialog the open view will be selected by default. Make sure it's not selected.
That's something to check, but I doubt that's the problem. I don't know what the problem is though, sorry.
Wed, Nov 23, 2011 at 10:36:07 AM | Revit printing issue
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I use PDF Creator, and do not have this problem. I am using 2012, 64 bit.
Printing changes annotations on sheets
Thu, Sep 15, 2016 at 6:55:41 AM
double printing Revit 2018
Mon, Jul 9, 2018 at 3:35:04 PM
Printing issue
Wed, Jul 12, 2006 at 1:12:21 AM
Scope boxes printing, set not to print.
Tue, Feb 15, 2011 at 6:39:49 PM
printing in revit
Thu, Oct 22, 2009 at 10:26:33 AM
Page generation time: 2.0123
