65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Selection Failure
Tue, Nov 22, 2011 at 10:49:00 AM | Selection Failure
ndsmaug
We recently upgraded to version 2012 and now we have an issue with the reflected ceiling plans.  While in those views, we cannot select the ceilings that have been created either by using the "Tab" key, or doing a selection box.  Literally every other element (grids, walls, rooms, tags, etc.) can be selected, but the ceilings seem to be exempt.  If we do a selection box, the "filter" button does not become available, however, the in the Properties menu "Multiple Categories" becomes active, and ceilings are in the list.  I can create a new ceiling, however, once it is made, I am not allowed to select it.
The view range is set to unlimited top, cut at 7'-6" above related level, and has an unlimited depth.  All items are on in the visibility graphics.  I have started new ceiling plans and used the Revit defaults for view range, and get the same results.  These plans have not changed since the Revit 2011 version, and were working just fine last week.  I have also made sure the video driver Autodesk recommends is current.
 HELP!!!!!
 Any insight would be helpful.  Thank you so much.
Tue, Nov 22, 2011 at 4:26:43 PM | Selection Failure
aspect
Sounds bizarre, and the only thing I would double check is the ceiling hasnt been set as a Design Option - because it sounds like the type of thing that happens when an element is put into a 'Primary option', then the view is switched back to 'Main Model' - you can see the element, but cannot select it.
Apart from that, sounds like a call to your Autodesk rep might be the only solve.
www.aspectarch.com
Tue, Nov 22, 2011 at 5:03:30 PM | Selection Failure
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
do you have any lay in ceiling, perhaps something with a model hatch on it? if not then add a model hatch to one of your ceiling types and try to select the hatch.
i know this isnt a fix, I am just curious if it works
Edited on: Tue, Nov 22, 2011 at 5:04:03 PM
Wed, Nov 23, 2011 at 7:06:17 AM | Selection Failure
I have seen other questions like this that ended up being a video card problem.  Check your drivers.
Mon, Nov 28, 2011 at 8:52:21 AM | Selection Failure
ndsmaug
I've tried everything.  I'm troubleshooting the problem with Autodesk right now.  I have already sent them both my Central File and my Local, but they can't seem to recreate the problem.  I guess they have better video cards than we do.  I've been looking at posts from other people, and searching the web for similar issues, and the video card does seem to be the culprit.
Thanks for all your help guys!
selection issue
Fri, Mar 4, 2005 at 3:43:12 PM
Quit Deselecting My Selection!
Tue, Jan 13, 2009 at 10:24:46 AM
selection filter
Sun, May 21, 2006 at 9:32:57 PM
Stumped on why window selection or crossing selection wont pick pipe fittings ?
Sat, Jun 1, 2024 at 1:44:17 PM
program failure
Wed, Jul 4, 2018 at 3:03:38 PM
Page generation time: 0.8418
