131 Users Online (130 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Print to PDF
Mon, Nov 21, 2011 at 9:55:07 AM | Print to PDF
StaticDOS
Hi guys another question, im sure theres going to be a simple answer but its just annoying me so said id post here, im printing a sheet to PDF, the title block is A4 and the printer sheet size is set to A4 but when it prints to PDF theres a gap left around the sheet, how do I strech it so that it lines up with the border of the sheet
Dell Precision T1500 Intel(R) Core(TM) i5 CPU 660 @ 3.33GHz Installed Memory 4.00 GB
Mon, Nov 21, 2011 at 10:24:41 AM | Print to PDF
3.5 Stars: 393 Votes
Don't print to fit.  Print 100%
Mon, Nov 21, 2011 at 10:32:21 AM | Print to PDF
StaticDOS
Hi I also tried that but it just zooms up really close on a section of the sheet?
Mon, Nov 21, 2011 at 10:41:37 AM | Print to PDF
If your sheet is A4 then it will print correctly.  If you are trying to print a D size sheet on an A4 piece of paper, then everthing will be scaled and there will be an automatic border area based on the printer.  Instead, you will need to determine wath scale factor you want to print.
Mon, Nov 21, 2011 at 11:08:59 AM | Print to PDF
StaticDOS
Hi hub thanks the sheet I downloaded was the wrong scale, how do I change the size of the Viewport Title on my sheet as its way too large now?
Mon, Nov 21, 2011 at 11:18:40 AM | Print to PDF
Your questions indicate you are doing something wrong.
If you have the proper sized sheet and place a view on that sheet, the viewport title will be correct.  REVIT is not CAD so I hope you are not trying to do CAD processes.  View titles are set to print the same no matter what the sheet size is.
Tue, Nov 22, 2011 at 3:37:09 AM | Print to PDF
StaticDOS
So if im printing on an A4 sheet or an A1 sheet the Viewport title is going to print at the same size?
Tue, Nov 22, 2011 at 6:19:51 AM | Print to PDF
This is the magic of Revit.
If you print your sheets full size, all view titles will be the same real height on the page.  All text set at 1/8" will be physically 1/8" on every view where used.  No matter what the scale of the view is - no matter what the sheet size is.
Fri, Jan 23, 2015 at 6:12:01 AM | Print to PDF
KYLIEBRAITHWAITE
I am encountering the same problem. I changed fit to page to zoom 100% paper size and print setup is a1 and sheet template is a1.
what am i doing wrong?
Fri, Jan 23, 2015 at 6:25:15 AM | Print to PDF
KYLIEBRAITHWAITE
when i print zoom 100% instead of fit i get a cropped view.
i have tried my sheet templates on another revit file and it worked perfectly so i know its not the sheet template
Fri, Jan 23, 2015 at 6:47:45 AM | Print to PDF
#11
KYLIEBRAITHWAITE
worked it out Smile
i had loaded a sheet template with parameters ranging from a3-a0. it was picking up the a0 size even though the a1 family was being used. i have now deleted the sheet template and im soley using a titlebock with sheet dimensions and borders included. a3-a0 made separelt and not with parameters for differing sizes.
i hope this helps if anyone else has same difficulty.
I want to print the whole document to pdf In one step
Wed, Dec 8, 2004 at 7:23:00 AM
Print to PDF crashing
Tue, Apr 6, 2010 at 3:55:55 PM
PDF print, no window border
Thu, Jan 30, 2014 at 10:57:00 AM
Physical Print Quality of PDF's Produced from Revit
Tue, Apr 23, 2013 at 9:49:54 AM
printing large formats in pdf
Thu, Dec 29, 2011 at 6:25:11 PM
Page generation time: 0.5118
