47 Users Online (46 Members):
Forums >> Revit Structure >> Technical Support >> Family Floor Plan Visibility Issue
4 Posts No Rating |
Hi,
I'm working on a tiered seating arrangement in revit 2012, the floor plan view seems to cut off at around 1800mm and the whole seating unit needs to be about 10m high. This means I cannot place the seats on the tiered unit above this height, how can I change this so it is possible to place them? I have set all the work planes and it worked for the first 4 levels (under 1800mm) but I can not place anything on the 5th level or higher.
Hope this makes sense.
Thanks,
First thing is that you can always alter view ranges through VP.
Learn to use working model plans that you alter as needed and keep these seperate from your sheet views.
Second, in any view, you can add "plan rgions" that alter the view range for a specified area.
Ceiling Mounted Family Visibility in Floor Plan |
Tue, Feb 3, 2009 at 7:48:39 PM
Floor Plan View |
Sat, Mar 17, 2007 at 7:38:08 AM
visibility in plan |
Thu, Jul 12, 2007 at 5:59:30 PM
Floor plan visibility: All equipment on the floor below are showing! |
Wed, Nov 4, 2015 at 7:32:48 AM
Floor plan cuts off midway |
Fri, Jun 7, 2013 at 7:00:39 AM
Members: | 2022285 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
